									WPdiscuz Update - wpDiscuz Comment Author Info				            </title>
            <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/wpdiscuz-update/</link>
            <lastBuildDate>Mon, 20 Jul 2026 16:57:41 +0000</lastBuildDate>
                        <title>RE: WPdiscuz Update</title>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/wpdiscuz-update/#post-23287</link>
                        <pubDate>Mon, 25 May 2020 11:30:06 +0000</pubDate>
                        <description><![CDATA[Thanks. I updated all addons and it works again :)]]></description>
                        <content:encoded><![CDATA[<p>Thanks. I updated all addons and it works again :)</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-comment-author-info/">wpDiscuz Comment Author Info</category>                        <dc:creator>TB2020</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-author-info/wpdiscuz-update/#post-23287</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/wpdiscuz-update/#post-23283</link>
                        <pubDate>Mon, 25 May 2020 10:22:54 +0000</pubDate>
                        <description><![CDATA[@tbtb20202,
All is correct.
We&#039;ve already mentioned in all places that the old wpDiscuz addons don&#039;t work with wpDiscuz 7. Even on the Update wizard first step it says you that the new ver...]]></description>
                        <content:encoded><![CDATA[<p>@tbtb20202,</p>
<p>All is correct.</p>
<p>We've already mentioned in all places that the old wpDiscuz addons don't work with wpDiscuz 7. Even on the Update wizard first step it says you that the new version should be installed and the current versions are disabled. This is the reason why it disables all addons. Please read the update doc: https://wpdiscuz.com/docs/wpdiscuz-7/plugin-installation/update-to-wpdiscuz-7/#3-updating-addons</p>
<p>To solve the problems you should update your addons to new 7.x.x versions. Just make sure, your addon licenses are not expired, then navigate to <span style="color: #008080">Dashboard &gt;Plugins</span> admin page and update all addons.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-comment-author-info/">wpDiscuz Comment Author Info</category>                        <dc:creator>Tom</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-author-info/wpdiscuz-update/#post-23283</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/wpdiscuz-update/#post-23279</link>
                        <pubDate>Mon, 25 May 2020 09:09:16 +0000</pubDate>
                        <description><![CDATA[For example.. wpDiscuz Comment Author Info. When clicking on a users avatar there used to be a popup with some info. This function seems to be disappeared]]></description>
                        <content:encoded><![CDATA[<p>For example.. wpDiscuz Comment Author Info. When clicking on a users avatar there used to be a popup with some info. This function seems to be disappeared</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-author-info/wpdiscuz-update/#post-23279</guid>
                        <title>WPdiscuz Update</title>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/wpdiscuz-update/#post-23277</link>
                        <pubDate>Mon, 25 May 2020 09:01:06 +0000</pubDate>
                        <description><![CDATA[After the last WPdiscuz update all addons were disable. When I enable it does not seem to do anything. Are the addons still suported in the new WPdiscuz version? Many functions seems to be a...]]></description>
                        <content:encoded><![CDATA[<p>After the last WPdiscuz update all addons were disable. When I enable it does not seem to do anything. Are the addons still suported in the new WPdiscuz version? Many functions seems to be added in the basic free version.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-author-info/wpdiscuz-update/#post-23277</guid>
