									Comment authors are wrong since update - wpDiscuz Comment Author Info				            </title>
            <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/</link>
            <lastBuildDate>Fri, 14 Aug 2026 15:47:22 +0000</lastBuildDate>
                        <title>RE: Comment authors are wrong since update</title>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23522</link>
                        <pubDate>Thu, 28 May 2020 09:00:20 +0000</pubDate>
                        <description><![CDATA[@cheryldimof,
Please send the admin login details to infogvectors.com email address, the developers fix it for you.]]></description>
                        <content:encoded><![CDATA[<p>@cheryldimof,</p>
<p>Please send the admin login details to infogvectors.com email address, the developers fix it for you.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-comment-author-info/">wpDiscuz Comment Author Info</category>                        <dc:creator>Elvina</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23522</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23502</link>
                        <pubDate>Thu, 28 May 2020 02:19:36 +0000</pubDate>
                        <description><![CDATA[However, for new comments, it&#039;s attributing them just fine. But I cannot see any way to fix the old ones unless there&#039;s a table in the database that could be repaired with search and replace...]]></description>
                        <content:encoded><![CDATA[<p>However, for new comments, it's attributing them just fine. But I cannot see any way to fix the old ones unless there's a table in the database that could be repaired with search and replace. As I said, I made those comments when I was logged in.</p>
<p>Thanks</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/wpdiscuz-comment-author-info/">wpDiscuz Comment Author Info</category>                        <dc:creator>cheryldimof</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23502</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23501</link>
                        <pubDate>Thu, 28 May 2020 02:11:24 +0000</pubDate>
                        <description><![CDATA[I was logged in when I wrote all of those comments and, prior to the recent update, I was identified as the post author on the comments. The different guest usernames only occurred after the...]]></description>
                        <content:encoded><![CDATA[<p>I was logged in when I wrote all of those comments and, prior to the recent update, I was identified as the post author on the comments. The different guest usernames only occurred after the update.</p>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23501</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23460</link>
                        <pubDate>Wed, 27 May 2020 15:24:43 +0000</pubDate>
For the comments that you mentioned, the comment authors are different because, you are not logged in when you wrote those comments.]]></description>
<p>For the comments that you mentioned, the comment authors are different because, you are not logged in when you wrote those comments.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23460</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23452</link>
                        <pubDate>Wed, 27 May 2020 13:15:41 +0000</pubDate>
                        <description><![CDATA[Hi, 
I have looked at it both logged in and logged out. Each one of my comments is attributed to a different guest author.
Thanks]]></description>
                        <content:encoded><![CDATA[<p>Hi, </p>
<p>I have looked at it both logged in and logged out. Each one of my comments is attributed to a different guest author.</p>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23452</guid>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23445</link>
                        <pubDate>Wed, 27 May 2020 12:23:51 +0000</pubDate>
                        <description><![CDATA[Hi @cheryldimof,
Please make sure you are logged in and check again.]]></description>
                        <content:encoded><![CDATA[<p>Hi <span>@cheryldimof,</span></p>
<p>Please make sure you are logged in and check again. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23445</guid>
                        <title>Comment authors are wrong since update</title>
                        <link>https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23410</link>
                        <pubDate>Tue, 26 May 2020 22:32:24 +0000</pubDate>
                        <description><![CDATA[Hello,
I did the update and ran all of the recommended updates after the plugins updates, but now I&#039;m finding that the comment authors are wrong. Fortunately, I don&#039;t have that many comment...]]></description>
                        <content:encoded><![CDATA[<p>Hello,</p>
<p>I did the update and ran all of the recommended updates after the plugins updates, but now I'm finding that the comment authors are wrong. Fortunately, I don't have that many comments on the blog.</p>
<p>For instance, I am the site admin. Comments I left used to show the admin or post author badge under my gravatar and if I clicked the comment author info it would show how many comments I had written.</p>
<p>Now, every comment I left has a different @ username for user mentioning. I have a post I've left a few comments on and they are all attributed now to a different username (one <span>(@guest_7), one (@guest_49), etc even though I'm site admin. And if I click on any one of them to bring up the comment author info popup, it says that I have 0 comments.</span></p>
<p>I've tried editing the comment, but it still attributes each one of them to a separate guest account.</p>
<p>Here's a post with just a few comments made by me, each attributed to a different guest @username:</p>
<p><a href="https://www.pnwbeyond.com/washington-state-hobbit-houses/">https://www.pnwbeyond.com/washington-state-hobbit-houses/</a></p>
<p>And when I tried editing my email, I started getting the default guest icon I set in settings.</p>
<p>And, speaking of that, I set a default guest icon and it's showing in admin but not for a guest on the front of the site.</p>
<p>Thanks,</p>
<p>Cheryl</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/wpdiscuz-comment-author-info/comment-authors-are-wrong-since-update/#post-23410</guid>
