									There is a problem with mycred integration - wpDiscuz - myCRED Integration				            </title>
            <link>https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/</link>
            <lastBuildDate>Mon, 13 Apr 2026 08:27:48 +0000</lastBuildDate>
                        <title>RE: There is a problem with mycred integration</title>
                        <link>https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27621</link>
                        <pubDate>Wed, 10 Mar 2021 07:36:55 +0000</pubDate>
                        <description><![CDATA[@good99,
If the WP Offload Media Lite plugin causes the issue, you should contact the plugin support and ask them to check the issue. Probably there is some setting, you should configure.]]></description>
                        <content:encoded><![CDATA[<p>@good99,</p>
<p style="text-align: left">If the WP Offload Media Lite plugin causes the issue, you should contact the plugin support and ask them to check the issue. Probably there is some setting, you should configure. </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/mycred-integration/">wpDiscuz - myCRED Integration</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27621</guid>
                        <link>https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27620</link>
                        <pubDate>Wed, 10 Mar 2021 07:09:51 +0000</pubDate>
                        <description><![CDATA[So, the only solution is to stop WP Offload Media Lite plugin?
WP Offload Media Lite plugin is very important to me]]></description>
                        <content:encoded><![CDATA[<p>So, the only solution is to stop WP Offload Media Lite plugin?</p>
<p> </p>
<p>WP Offload Media Lite plugin is very important to me</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/mycred-integration/">wpDiscuz - myCRED Integration</category>                        <dc:creator>榮 李</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27620</guid>
                        <link>https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27557</link>
                        <pubDate>Sun, 07 Mar 2021 04:17:31 +0000</pubDate>
<p> </p>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27557</guid>
                        <link>https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27457</link>
                        <pubDate>Wed, 03 Mar 2021 12:47:58 +0000</pubDate>
One of the active plugins change the image path. Please watch this video.]]></description>
<p>One of the active plugins change the image path. Please watch this video. https://www.screencast.com/t/5Os3EFKYJE</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27457</guid>
                        <link>https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27456</link>
                        <pubDate>Wed, 03 Mar 2021 12:33:13 +0000</pubDate>
                        <description><![CDATA[@astghik I tried according to your method, the problem still exists?Is there any possible fix?]]></description>
                        <content:encoded><![CDATA[<span style="vertical-align: inherit"><span style="vertical-align: inherit">@astghik I tried according to your method, the problem still exists?<br />Is there any possible fix?</span></span>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27456</guid>
                        <link>https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27445</link>
                        <pubDate>Wed, 03 Mar 2021 08:50:55 +0000</pubDate>
The issue may come from the WP Offload Media Lite plugin. Please deactivate the plugin delete all kind of caches (website, browser, CDN) and check again.]]></description>
<p>The issue may come from the WP Offload Media Lite plugin. Please deactivate the plugin delete all kind of caches (website, browser, CDN) and check again. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27445</guid>
                        <link>https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27430</link>
                        <pubDate>Tue, 02 Mar 2021 12:58:40 +0000</pubDate>
                        <description><![CDATA[@astghik I resend it to you]]></description>
                        <content:encoded><![CDATA[<span style="vertical-align: inherit"><span style="vertical-align: inherit">@astghik I resend it to you</span></span>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27430</guid>
                        <link>https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27429</link>
                        <pubDate>Tue, 02 Mar 2021 12:39:14 +0000</pubDate>
We got the following error message:]]></description>
<p>We got the following error message: </p>
5269]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27429</guid>
                        <link>https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27428</link>
                        <pubDate>Tue, 02 Mar 2021 12:35:20 +0000</pubDate>
                        <description><![CDATA[@astghik  I have sent an email to you, please check]]></description>
                        <content:encoded><![CDATA[@astghik  I have sent an email to you, please check]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27428</guid>
                        <link>https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27427</link>
                        <pubDate>Tue, 02 Mar 2021 11:21:46 +0000</pubDate>
Could you please send the admin login detail to infogvectors.com email address? I&#039;ll ask the developers to check the issue for you.]]></description>
                        <content:encoded><![CDATA[<p><span>@good99,</span></p>
<p>Could you please send the admin login detail to infogvectors.com email address? I'll ask the developers to check the issue for you. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/there-is-a-problem-with-mycred-integration/#post-27427</guid>
