									Problem with mobile comment view and MyCred - wpDiscuz - myCRED Integration				            </title>
            <link>https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/</link>
            <lastBuildDate>Fri, 09 Oct 2026 03:58:57 +0000</lastBuildDate>
                        <title>RE: Problem with mobile comment view and MyCred</title>
                        <link>https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20829</link>
                        <pubDate>Sat, 07 Mar 2020 09:32:52 +0000</pubDate>
                        <description><![CDATA[@johannes,
Now the avatar is far too small
Please note that in the mobile view the avatars are small.
We&#039;ve seen the small issues with the alignment, to solve the issue please use the...]]></description>
                        <content:encoded><![CDATA[<p>@johannes,</p>
<blockquote>
<p><span>Now the avatar is far too small</span></p>
</blockquote>
<p>Please note that in the mobile view the avatars are small.</p>
<p>We've seen the small issues with the <span><em><strong>alignment</strong></em>, to solve the issue</span> please use the following code: </p>
<pre><span>@media screen and (max-width: 420px){</span><br /><span>    #wpcomm .wpdiscuz-mycred-badges-wrap, #wpcomm .wpdiscuz-mycred-points-wrap, #wpcomm .wpdiscuz-mycred-rank-wrap{</span><br /><span>    text-align: center !important;</span><br /><span> }</span><br /><span> #wpcomm .wc-comment-header {</span><br /><span>    margin-left: 0 !important;</span><br /><span> }</span><br /><span> #wpcomm .wpdiscuz-mycred-wrap{</span><br /><span>    padding-top: 45px;</span><br /><span> }</span><br /><span>}<br /></span></pre>
<p>However, this will be fixed in the next version update. You'll just need to wait a bit.</p>
<p> </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/mycred-integration/">wpDiscuz - myCRED Integration</category>                        <dc:creator>Elvina</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20829</guid>
                        <link>https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20729</link>
                        <pubDate>Mon, 02 Mar 2020 11:51:26 +0000</pubDate>
                        <description><![CDATA[Hey,
It looks a bit better but it still has a problem. Now the avatar is far too small.
Johannes]]></description>
                        <content:encoded><![CDATA[<p>Hey,</p>
<p>It looks a bit better but it still has a problem. Now the avatar is far too small.</p>
<p>Johannes</p>
4062
						                            <category domain="https://gvectors.com/forum/mycred-integration/">wpDiscuz - myCRED Integration</category>                        <dc:creator>Johannes</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20729</guid>
                        <link>https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20564</link>
                        <pubDate>Mon, 24 Feb 2020 10:46:53 +0000</pubDate>
The issue is solved by our developers. We&#039;ve added the CSS code in the &quot;Custom CSS code&quot; textarea.&nbsp;
You&#039;ll need to remove those codes after the plugin update.&nbsp;
The CS...]]></description>
<p>The issue is solved by our developers. We've added the CSS code in the "Custom CSS code" textarea.&nbsp;</p>
<p>You'll need to remove those codes after the plugin update.&nbsp;</p>
<p>The CSS code added by us is provided below:</p>
<pre>@media screen and (max-width: 800px){<br />   #wpcomm .wc-comment{<br />     display: flex;<br />     flex-wrap: wrap;<br />   }<br />   #wpcomm .wc-comment &gt; *{<br />     flex: 1 1 100%;<br />   }<br />   #wpcomm .wc-comment .wc-comment-left{<br />     flex: 0 0 20%;<br />   }<br />   #wpcomm .wc-thread-wrapper .wc-comment .wc-comment-right{<br />     flex: 0 0 80%;<br />   }<br />   #wpcomm .wc-reply .wc-comment-header, #wpcomm .wc-comment-header{<br />      margin-left: 0;<br />   }<br />   #wpcomm .wc-comment-header{<br />      padding-left: 8px;<br />   }<br />   #wpcomm .wc-comment .wc-comment-left .avatar, #wpcomm .wc-reply.wc-comment .wc-comment-left .avatar{<br />      margin: auto !important;<br />      float: none !important;<br />}<br />   #wpcomm .wpdiscuz-mycred-rank-wrap, #wpcomm .wpdiscuz-mycred-badges-wrap, #wpcomm .wpdiscuz-mycred-points-wrap{<br />      text-align: center;<br />    }<br />}</pre>
<p><span>Please try on&nbsp;</span><em><strong>incognito mode.</strong>&nbsp;</em><span>Because mobile browsers have a hard cache, you'll not be able to see the change immediately.</span></p>
<p>&nbsp;</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/mycred-integration/">wpDiscuz - myCRED Integration</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20564</guid>
                        <link>https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20560</link>
                        <pubDate>Mon, 24 Feb 2020 08:33:16 +0000</pubDate>
                        <description><![CDATA[You can check it here:
I sent you the login data via pm
                        <content:encoded><![CDATA[<p>You can check it here: <a href="https://www.meeplemansion.de/spiele/strategiespiele/top-10-die-besten-strategiespiele/">https://www.meeplemansion.de/spiele/strategiespiele/top-10-die-besten-strategiespiele/</a></p>
<p>I sent you the login data via pm</p>
<p>Johannes</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20560</guid>
                        <link>https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20553</link>
                        <pubDate>Mon, 24 Feb 2020 08:05:11 +0000</pubDate>
                        <description><![CDATA[Hi @johannes,
Please leave some example URL to allow us to check it.]]></description>
                        <content:encoded><![CDATA[<p>Hi <span>@johannes,</span></p>
<p>Please leave some example URL to allow us to check it. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20553</guid>
                        <title>Problem with mobile comment view and MyCred</title>
                        <link>https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20542</link>
                        <pubDate>Sat, 22 Feb 2020 13:54:34 +0000</pubDate>
in mobile view (max width 800px) the comment view is broken when using MyCred badges. How would I fix that?
Best
<p>in mobile view (max width 800px) the comment view is broken when using MyCred badges. How would I fix that?</p>
<p>Best</p>
<p>Johannes</p>
4043
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/problem-with-mobile-comment-view-and-mycred/#post-20542</guid>
