									Points display issues - wpDiscuz - myCRED Integration				            </title>
            <link>https://gvectors.com/forum/mycred-integration/points-display-issues/</link>
            <lastBuildDate>Sat, 11 Apr 2026 02:44:44 +0000</lastBuildDate>
                        <title>RE: Points display issues</title>
                        <link>https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20816</link>
                        <pubDate>Fri, 06 Mar 2020 16:45:32 +0000</pubDate>
                        <description><![CDATA[@elvina
You&#039;re very welcome!&nbsp;&nbsp;
&nbsp;
Thanks and take care,&nbsp;
-Chris
&nbsp;]]></description>
                        <content:encoded><![CDATA[<p>@elvina</p>
<p>You're very welcome!&nbsp;&nbsp;</p>
<p>&nbsp;</p>
<p>Thanks and take care,&nbsp;</p>
<p>-Chris</p>
<p>&nbsp;</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/mycred-integration/">wpDiscuz - myCRED Integration</category>                        <dc:creator>ChrisR</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20816</guid>
                        <link>https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20806</link>
                        <pubDate>Fri, 06 Mar 2020 09:02:28 +0000</pubDate>
                        <description><![CDATA[@chris-r,
Thank you for sharing the information.
We&#039;ll take it into consideration and try to add in the next versions update.
                        <content:encoded><![CDATA[<p>@chris-r,</p>
<p>Thank you for sharing the information.</p>
<p>We'll take it into consideration and try to add in the next versions update.</p>
						                            <category domain="https://gvectors.com/forum/mycred-integration/">wpDiscuz - myCRED Integration</category>                        <dc:creator>Elvina</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20806</guid>
                        <link>https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20799</link>
                        <pubDate>Thu, 05 Mar 2020 17:41:01 +0000</pubDate>
                        <description><![CDATA[Hi Elvina, 
I explained the situation to the MyCred developers and heard back from them.  This is their response:
These are third party plugins they are not using the function whic...]]></description>
                        <content:encoded><![CDATA[<p>Hi Elvina, </p>
<p> </p>
<p>I explained the situation to the MyCred developers and heard back from them.  This is their response:</p>
<p> </p>
<blockquote>
<p>These are third party plugins they are not using the function which adds the comma in the points.<br />They can use the below example code in their plugins to make the points format as per the settings.</p>
<p>$point_balance = new myCRED_Point_Type();</p>
<p>$point_balance-&gt;format( 16040 );</p>
<p><a href="https://codex.mycred.me/objects/mycred_point_type/" rel="nofollow">https://codex.mycred.me/objects/mycred_point_type/</a></p>
<p> </p>
</blockquote>
<p>Hopefully this helps. </p>
<p> </p>
<p>Thank you, </p>
<p>-Chris</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20799</guid>
                        <link>https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20783</link>
                        <pubDate>Wed, 04 Mar 2020 17:20:05 +0000</pubDate>
&nbsp;
Hi Elvina,&nbsp;
&nbsp;
Man! You&#039;re on top of this forum!&nbsp; I really appreciate the help.&nbsp;&nbsp;
&nbsp;
Posted by: @elvina 
Please navigate to the Dashboard ...]]></description>
<p>&nbsp;</p>
<p>Hi Elvina,&nbsp;</p>
<p>&nbsp;</p>
<p>Man! You're on top of this forum!&nbsp; I really appreciate the help.&nbsp;&nbsp;</p>
<p>&nbsp;</p>
<blockquote data-userid="13418" data-postid="20778" data-mention="elvina">
<div class="wpforo-post-quote-author"><strong>Posted by: @elvina </strong></div>
<p>Please navigate to the Dashboard &gt; Comments &gt; Settings &gt; Styling admin page, put the following CSS code in the "Custom CSS code" textarea:</p>
<pre>#wpcomm .wpdiscuz-mycred-points-wrap {<br />text-transform: none !important;<br />}</pre>
</blockquote>
<p>That worked like a charm!</p>
<p>&nbsp;</p>
<p><span>The issue will be fixed in the next version update.</span></p>
<p><span>In case if&nbsp; you want to solve it as soon as possible please follow the steps below:</span></p>
<p><span>1. Find this line:</span></p>
<pre><span>$afterLabelHtml .= '&lt;div class="wpdiscuz-mycred-points-wrap"&gt;' . $pointsLable . ':' . $balance . '&lt;/div&gt;';</span></pre>
<p><span>2. Replace with the following one:</span></p>
<pre><span>$afterLabelHtml .= '&lt;div class="wpdiscuz-mycred-points-wrap"&gt;' . $pointsLable . ':' . '&amp;nbsp' . $balance . '&lt;/div&gt;';</span></pre>
<p><span>Don't forget to delete all caches and press CTRL+F5(twice) on the frontend before checking.</span></p>
</blockquote>
<p>Awesome!&nbsp; I'm glad its being fixed in an update, I think I'll just wait for that.&nbsp; I do appreciate you offering a quick fix in case I needed it right way.&nbsp;</p>
<p>&nbsp;</p>
<blockquote>
<p><span>3. There should be a use of a comma when thousandths are used.&nbsp; This is also an issue is the wpFORO addon and should be fixed there as well.&nbsp;</span></p>
</blockquote>
<p>We'll take it into consideration.&nbsp;</p>
<p>However the Points value comes from <a href="https://wordpress.org/plugins/mycred/" target="true" rel="nofollow">MyCred</a> plugin, so it will be better if you contact MyCred plugin support and asked them this question.</p>
<p>&nbsp;</p>
</blockquote>
<p>Hmm. that's weird, the points are showing up with a comma in both my theme (Logged in menu) and the Ultimate Member profile.&nbsp; The only places they aren't are wpForo and wpDiscuz.&nbsp;</p>
<p>&nbsp;</p>
<p>I will try to reach out to the MyCred team though like you suggested and see what I can figure out.&nbsp;</p>
<p>&nbsp;</p>
<p>Thanks again Elvina,</p>
<p>-Chris</p>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20783</guid>
                        <link>https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20778</link>
                        <pubDate>Wed, 04 Mar 2020 08:47:00 +0000</pubDate>
Thank you.
1. The P should be capitalized like it is in the wpForo myCRED addon.&nbsp;
Please navigate to the Dashboard &gt; Comments &gt; Settings &gt; Styling admin page, ...]]></description>
<p>Thank you.</p>
<blockquote>
<p><span>1. The P should be capitalized like it is in the wpForo myCRED addon.&nbsp;</span></p>
</blockquote>
<blockquote>
<p><span>2. There should be a space right after the colon and before the first digit. It's also like it is in wpForo myCRED addon.&nbsp;&nbsp;</span></p>
</blockquote>
<blockquote>
</blockquote>
<p>However the Points value comes from <a href="https://wordpress.org/plugins/mycred/" target="true">MyCred</a> plugin, so it will be better if you contact MyCred plugin support and asked them this question.</p>
<p>&nbsp;</p>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20778</guid>
                        <link>https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20771</link>
                        <pubDate>Tue, 03 Mar 2020 15:44:10 +0000</pubDate>
Hi Elvina,&nbsp;
&nbsp;
I just pm&#039;ed you with the links.
&nbsp;
Thank you,&nbsp;
-Chris&nbsp;
<p>&nbsp;</p>
<p>I just pm'ed you with the links.</p>
<p>&nbsp;</p>
<p>Thank you,&nbsp;</p>
<p>-Chris&nbsp;</p>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20771</guid>
                        <link>https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20748</link>
                        <pubDate>Tue, 03 Mar 2020 08:51:52 +0000</pubDate>
                        <description><![CDATA[Hi @chris-r,
Please leave the example URL to allow us to check it.]]></description>
                        <content:encoded><![CDATA[<p>Hi <span>@chris-r,</span></p>
<p>Please leave the example URL to allow us to check it.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20748</guid>
                        <title>Points display issues</title>
                        <link>https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20738</link>
                        <pubDate>Mon, 02 Mar 2020 20:59:26 +0000</pubDate>
                        <description><![CDATA[Hello, 
There are a few issues with the displaying of points.  They currently display like this: points:19000
I believe they should look like this: Points: 19,000
1. The P should...]]></description>
                        <content:encoded><![CDATA[<p>Hello, </p>
<p> </p>
<p>There are a few issues with the displaying of points.  They currently display like this: points:19000</p>
<p> </p>
<p>I believe they should look like this: Points: 19,000</p>
<p> </p>
<p>1. The P should be capitalized like it is in the wpForo myCRED addon. </p>
<p>2. There should be a space right after the colon and before the first digit. It's also like it is in wpForo myCRED addon.  </p>
<p>3. There should be a use of a comma when thousandths are used.  This is also an issue is the wpFORO addon and should be fixed there as well. </p>
<p> </p>
<p>You can see the attached screenshots for reference.</p>
<p> </p>
<p>wpDiscuz example</p>
4069
<p> </p>
<p>wpForo example</p>
4068
<p> </p>
<p>Thank you, </p>
<p>-Chris</p>
<p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/points-display-issues/#post-20738</guid>
