									Point type shown with lower case letter - wpDiscuz - myCRED Integration				            </title>
            <link>https://gvectors.com/forum/mycred-integration/point-type-shown-with-lower-case-letter/</link>
            <lastBuildDate>Thu, 21 May 2026 17:21:37 +0000</lastBuildDate>
                        <title>RE: Point type shown with lower case letter</title>
                        <link>https://gvectors.com/forum/mycred-integration/point-type-shown-with-lower-case-letter/#post-20435</link>
                        <pubDate>Wed, 19 Feb 2020 08:49:48 +0000</pubDate>
                        <description><![CDATA[@johannes,
Thank you for details.
As we can see you use the wpDiscuz &ndash; myCRED Integration add-on, not the wpforo &ndash; myCRED Integration odd-on. So this topic is moved to the curr...]]></description>
                        <content:encoded><![CDATA[<p>@johannes,</p>
<p>Thank you for details.</p>
<p>As we can see you use the wpDiscuz &ndash; myCRED Integration add-on, not the wpforo &ndash; myCRED Integration odd-on. So this topic is moved to the current forum.</p>
<p>First of all, you'll need to fix the issue mentioned in this post.</p>
<p><a href="../../wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20433">https://gvectors.com/forum/wpdiscuz-frontend-moderation/wpdiscuz-frontend-moderation-and-defender-pro/#post-20433</a></p>
<p>Then navigate to the Dashboard &gt; Comments &gt;Settings &gt; Styling admin page put the following CSS code in the "Custom CSS code" textarea:</p>
<pre>#wpcomm .wpdiscuz-mycred-points-wrap {<br />   text-transform: none !important;<br />}</pre>
<p>Don't forget to delete all caches and press CTRL+F5(twice) on the frontend before checking.</p>
<p>&nbsp;</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/mycred-integration/">wpDiscuz - myCRED Integration</category>                        <dc:creator>Elvina</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/point-type-shown-with-lower-case-letter/#post-20435</guid>
                        <link>https://gvectors.com/forum/mycred-integration/point-type-shown-with-lower-case-letter/#post-20414</link>
                        <pubDate>Tue, 18 Feb 2020 12:58:21 +0000</pubDate>
                        <description><![CDATA[Yes, the problem is still there. I wrote you a PM]]></description>
                        <content:encoded><![CDATA[<p>Yes, the problem is still there. I wrote you a PM</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/mycred-integration/">wpDiscuz - myCRED Integration</category>                        <dc:creator>Johannes</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/point-type-shown-with-lower-case-letter/#post-20414</guid>
                        <link>https://gvectors.com/forum/mycred-integration/point-type-shown-with-lower-case-letter/#post-20413</link>
                        <pubDate>Tue, 18 Feb 2020 12:50:33 +0000</pubDate>
                        <description><![CDATA[Hi @johannes, 
Please navigate to the Dashboard &gt; Forums &gt; Dashboard admin page click on the &quot;Delete All Caches&quot; button, then go to frontend page click CTRL+F5(twice) on the frontend ...]]></description>
                        <content:encoded><![CDATA[<p>Hi <span>@johannes, </span></p>
<p>Please navigate to the Dashboard &gt; Forums &gt; Dashboard admin page click on the "<span>Delete All Caches" button, then go to frontend page click CTRL+F5(twice) on the frontend and check again.</span></p>
<p>If the issue still exists please leave the example URL to allow us to check it.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/point-type-shown-with-lower-case-letter/#post-20413</guid>
                        <title>Point type shown with lower case letter</title>
                        <link>https://gvectors.com/forum/mycred-integration/point-type-shown-with-lower-case-letter/#post-20412</link>
                        <pubDate>Tue, 18 Feb 2020 12:34:56 +0000</pubDate>
                        <description><![CDATA[Hey guys,
I am having a weird problem with the output of the point type name. It is shown in lower case letters, although the actual html code has a upper case first letter. What you see: &quot;...]]></description>
                        <content:encoded><![CDATA[<p>Hey guys,</p>
<p>I am having a weird problem with the output of the point type name. It is shown in lower case letters, although the actual html code has a upper case first letter. What you see: "siegpunkte", what the html says and should be shown: "Siegpunkte". Do you have an idea what is causing this?</p>
<p>Best</p>
<p>Johannes</p>
4026
<p> . </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/mycred-integration/point-type-shown-with-lower-case-letter/#post-20412</guid>
