									Removing /Replacing the Add a Comment Placeholder. - How-To and Troubleshooting				            </title>
            <link>https://gvectors.com/forum/how-to-and-troubleshooting/removing-replacing-the-add-a-comment-placeholder/</link>
            <lastBuildDate>Fri, 14 Aug 2026 16:01:01 +0000</lastBuildDate>
                        <title>RE: Removing /Replacing the Add a Comment Placeholder.</title>
                        <link>https://gvectors.com/forum/how-to-and-troubleshooting/removing-replacing-the-add-a-comment-placeholder/#post-23291</link>
                        <pubDate>Mon, 25 May 2020 12:07:52 +0000</pubDate>
                        <description><![CDATA[Perfect. Thank you. The new version looks like a significant enhancement/improvement in terms of customisation and fuctionality]]></description>
                        <content:encoded><![CDATA[<p>Perfect. Thank you. The new version looks like a significant enhancement/improvement in terms of customisation and fuctionality</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/how-to-and-troubleshooting/">How-To and Troubleshooting</category>                        <dc:creator>tobydoyle</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/how-to-and-troubleshooting/removing-replacing-the-add-a-comment-placeholder/#post-23291</guid>
                        <link>https://gvectors.com/forum/how-to-and-troubleshooting/removing-replacing-the-add-a-comment-placeholder/#post-23290</link>
                        <pubDate>Mon, 25 May 2020 11:50:51 +0000</pubDate>
                        <description><![CDATA[Hi @tobydoyle,
1. To remove the placeholder text you can use the following JS code. 
jQuery(&quot;#wpdcom .ql-editor.ql-blank&quot;).removeAttr(&quot;data-placeholder&quot;);
The code should be added in the ...]]></description>
                        <content:encoded><![CDATA[<p>Hi <span>@tobydoyle,</span></p>
<p>1. To remove the placeholder text you can use the following JS code. </p>
<pre>jQuery("#wpdcom .ql-editor.ql-blank").removeAttr("data-placeholder");</pre>
<p>The code should be added in the current active theme js files.</p>
<p>2. To change the text just navigate to the Dashboard &gt; Comments &gt; wpDiscus  &gt; Phrases admin page, find and change each phrase you need.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/how-to-and-troubleshooting/">How-To and Troubleshooting</category>                        <dc:creator>Elvina</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/how-to-and-troubleshooting/removing-replacing-the-add-a-comment-placeholder/#post-23290</guid>
                        <title>Removing /Replacing the Add a Comment Placeholder.</title>
                        <link>https://gvectors.com/forum/how-to-and-troubleshooting/removing-replacing-the-add-a-comment-placeholder/#post-23286</link>
                        <pubDate>Mon, 25 May 2020 11:10:35 +0000</pubDate>
                        <description><![CDATA[We are planning to use Discuz to enable people to leave messages of condolences on our memorial site as well as to leave comments on our post.
The &quot;Be the First to Comment&quot; placeholder is i...]]></description>
                        <content:encoded><![CDATA[<p>We are planning to use Discuz to enable people to leave messages of condolences on our memorial site as well as to leave comments on our post.</p>
<p>The "Be the First to Comment" placeholder is inappropriate on Memorial pages - see:</p>
<p><a href="https://memorialise.co.uk/events/united-kingdom/greater-manchester/middleton/marjorie-andrew/#reviews">https://memorialise.co.uk/events/united-kingdom/greater-manchester/middleton/marjorie-andrew/#reviews</a></p>
<p>I had changed it before using Custom CSS but this seems to have moved/disappeared in V7.</p>
<p>Can you indicate where/how I can edit/remove it, preferably in a way which will not be brought back with updates. </p>
<p>Either removing it altogether would be fine --  or changing it to to "Be the First to Post" or "Be the First to Post a Message of Condolence" preferable.</p>
<p>Best wishes</p>
<div class="wpf-post-button-actions"> </div>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/how-to-and-troubleshooting/removing-replacing-the-add-a-comment-placeholder/#post-23286</guid>
