[Solved] Problem with OAuth
(@baymi)
Good day, please help to understand. When I click button login with Facebook, Twitter, Google and other social networks, the page is updated, but no login is made. But after manually updating the page, an account is entered. I set everything up according to the instructions. Facebook said, solve this problem soon, or get sanctions. Website address https://epilogue.club  . Thanks.
H @baymi,
Could you please deactivate the cache plugin you're using and check again?
(@baymi)
Hi, I deactivated W3 Total Cache and Webcraftic plugins and other optimization plugins. The problem remains relevant (
(@baymi)
Do you have any other ideas?
Hi @baymi,
I've already reported this issue to our developers. They are checking the issue. I'll update this topic asap.
(@baymi)
Thanks, it's a pleasure to work with you team.
(@baymi)
I corrected this error. The problem was that the caching was in the htaccess file. I turned it on to compress images, simultaneously turned on compression for js scripts and other objects. Disabling these settings, the plugin shows stable operation. Thanks again for the quality plugin.
Astghik reacted
Hi @baymi,
Thank you very much for letting us know. Glad to hear that the issue is solved.
I really appreciate you taking a time and share the information here.
