[Solved] How to test, if Lazy load Comments function works?
(@dooomer)
Topic starter   [#4713]
Hi there, in wpDiscuz settings is option for Lazy load comments. I turned it ON, but is there any way/guide, how I can check if this function works and ins't in conflict with our template Sahifa? (for example in Chrome DevTools) 🙂
Topic Tags
Hi @dooomer,
If you enable the Lazy Load option only the first X number of comment threads are loaded with a post.
It starts loading another X comment thread when you scroll down. The X number of comment threads per loading action is defined in WordPress discussion settings and used by [Load more] or the Lazy Load types. More info here:
https://wpdiscuz.com/docs/wpdiscuz-documentation/settings/comment-list-settings/#pagination
Below is provided the link that can help you to debug js errors in different browsers:
https://wordpress.org/support/article/using-your-browser-to-diagnose-javascript-errors/
(@dooomer)
ok, thank you 🙂
