									How to insert Rating Custom field above comment form? - How-To and Troubleshooting				            </title>
            <link>https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/</link>
            <lastBuildDate>Tue, 17 Nov 2026 19:50:23 +0000</lastBuildDate>
                        <title>RE: How to insert Rating Custom field above comment form?</title>
                        <link>https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18381</link>
                        <pubDate>Thu, 24 Oct 2019 12:49:49 +0000</pubDate>
                        <description><![CDATA[@elvina thank you]]></description>
                        <content:encoded><![CDATA[<p>@elvina thank you</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/how-to-and-troubleshooting/">How-To and Troubleshooting</category>                        <dc:creator>adarshm07</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18381</guid>
                        <link>https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18380</link>
                        <pubDate>Thu, 24 Oct 2019 12:44:22 +0000</pubDate>
                        <description><![CDATA[@adarshm07,The reply box section has the following class:.wc-secondary-form-wrapperYou can use the class and make manipulations with the elements of the reply box.E.g..wc-secondary-form-wrap...]]></description>
                        <content:encoded><![CDATA[<p>@adarshm07,</p><p>The reply box section has the following class:</p><pre>.wc-secondary-form-wrapper</pre><p>You can use the class and make manipulations with the elements of the reply box.</p><p>E.g.</p><pre>.wc-secondary-form-wrapper textarea{<br />   width: 350px; <br />}</pre>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/how-to-and-troubleshooting/">How-To and Troubleshooting</category>                        <dc:creator>Elvina</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18380</guid>
                        <link>https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18376</link>
                        <pubDate>Thu, 24 Oct 2019 11:49:01 +0000</pubDate>
                        <description><![CDATA[@elvinia can you please tell me the class names for reply form, I wanted to customize reply form.]]></description>
                        <content:encoded><![CDATA[<p>@elvinia can you please tell me the class names for reply form, I wanted to customize reply form.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18376</guid>
                        <link>https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18352</link>
                        <pubDate>Wed, 23 Oct 2019 10:29:26 +0000</pubDate>
                        <description><![CDATA[@elvinaIt worked with CSS, adding z-index solved the possible issue you told. Thank you]]></description>
                        <content:encoded><![CDATA[<p>@elvina</p><p>It worked with CSS, adding z-index solved the possible issue you told.</p><p> </p><p>Thank you</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18352</guid>
                        <link>https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18350</link>
                        <pubDate>Wed, 23 Oct 2019 10:10:33 +0000</pubDate>
                        <description><![CDATA[Hi @adarshm07,I apologize for the late response.I&#039;m sorry but there is no way to change the rating starts position. Even if you change the position via CSS or js it&#039;ll still not work.]]></description>
                        <content:encoded><![CDATA[<p>Hi @adarshm07,</p><p>I apologize for the late response.</p><p>I'm sorry but there is no way to change the rating starts position. Even if you change the position via CSS or js it'll still not work.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18350</guid>
                        <title>How to insert Rating Custom field above comment form?</title>
                        <link>https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18329</link>
                        <pubDate>Tue, 22 Oct 2019 07:02:07 +0000</pubDate>
                        <description><![CDATA[Expectation: The custom field for rating above the comment form and name and email id below comment form.]]></description>
                        <content:encoded><![CDATA[<p>Expectation: The custom field for rating above the comment form and name and email id below comment form.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/how-to-and-troubleshooting/how-to-insert-rating-custom-field-above-comment-form/#post-18329</guid>
