Gravatar Cache
  RSS
Amir
 Amir
(@amiremami)
Trusted Member
13/01/2018 2:21 pm
Hi 🙂
I have problem of gravatar cache. It ha been enabled and set on runtime 30 days, but it's not working. If you open ajibtarin.com and see the source code, you will see secure.gravatar.com
Support Team Admin
14/01/2018 7:53 pm
Hi Amir,
I'm sorry but there is no way to help you without having admin access. Please send admin login details if you want us to help you.
Amir
 Amir
(@amiremami)
Trusted Member
15/01/2018 1:55 pm
Hi Tom, thanks : )
I have sent an email to info@gvectors.com
Amir
 Amir
(@amiremami)
Trusted Member
15/01/2018 1:55 pm
Support Team Admin
16/01/2018 1:52 am
Thank you Amir,
We've checked and all works fine. There are three category of avatars and you should know which one is cached which is not:
1. Users who don't have Gravatar it loads the default avatar from plugin you use, it's not cached. wpDiscuz doesn't cache 3rd party plugins avatars.
2. All users with Gravatar are cached well and are loaded from cache.
3. All users who use Ultimate Member Plugin avatar, they are loaded from UM plugin source. As I've mentioned in #1 wpDiscuz doesn't cache those.
Amir
 Amir
(@amiremami)
Trusted Member
16/01/2018 1:55 am
Thank you so much Tom.
On homepage, in footer, this is url of your avatar:
&r=g
So why it's still loading from gravatar?
Amir
 Amir
(@amiremami)
Trusted Member
16/01/2018 1:57 am
Ah I noticed your avatar in post is
So, it seems the avatar not cache outside of post.
(@astghik)
Honorable Member Moderator
17/01/2018 5:20 pm
Hi Amir,
Please note it's impossible to cache avatars outside of wpDiscuz scope.
Amir
 Amir
(@amiremami)
Trusted Member
17/01/2018 5:24 pm
Ah I see, because it's the widget of last comments, I thought you support this, seems I need to use wp user avatar again, thanks a lot Tom for your great support 🙂
