Usage of shortcodes...
[Solved] Usage of shortcodes from other plugins
(@mateusz)
Is it possible to use shortcodes from other plugins on the forum?
For example, I use NinjaTables plugin to display tables. Can I paste the shortcode to display the table in the topic?
I cannot find the way to do this.
(@mateusz)
I found a setting in WPforo settings that allows to do this. 🙂 It was switched off by default, so I switched it on.
Solved.
Thank you for letting us know. Glad to hear that the issue is solved.
