									I would like to use the question and answer layout as well as the extended layout on the same installation - wpForo				            </title>
            <link>https://gvectors.com/forum/general-questions/i-would-like-to-use-the-question-and-answer-layout-as-well-as-the-extended-layout-on-the-same-installation/</link>
            <lastBuildDate>Thu, 12 Nov 2026 22:53:03 +0000</lastBuildDate>
                        <title>RE: I would like to use the question and answer layout as well as the extended layout on the same installation</title>
                        <link>https://gvectors.com/forum/general-questions/i-would-like-to-use-the-question-and-answer-layout-as-well-as-the-extended-layout-on-the-same-installation/#post-12757</link>
                        <pubDate>Thu, 03 Jan 2019 02:06:21 +0000</pubDate>
                        <description><![CDATA[Thank you, much appreciated.]]></description>
                        <content:encoded><![CDATA[<p>Thank you, much appreciated.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/general-questions/">wpForo</category>                        <dc:creator>GregT</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-questions/i-would-like-to-use-the-question-and-answer-layout-as-well-as-the-extended-layout-on-the-same-installation/#post-12757</guid>
                        <link>https://gvectors.com/forum/general-questions/i-would-like-to-use-the-question-and-answer-layout-as-well-as-the-extended-layout-on-the-same-installation/#post-12749</link>
                        <pubDate>Wed, 02 Jan 2019 13:25:49 +0000</pubDate>
                        <description><![CDATA[Hi @gregt,Yes it possible as you can see here on our support forum. You should have two top Categories (top parent forums). Edit those and set first Extended Forum Layout, Second Q&amp;A For...]]></description>
                        <content:encoded><![CDATA[<p>Hi @gregt,</p><p>Yes it possible as you can see here on our support forum. You should have two top Categories (top parent forums). Edit those and set first Extended Forum Layout, Second Q&amp;A Forum layout. Doc: https://wpforo.com/docs/root/categories-and-forums/forum-manager/add-new-forum/#forum-options</p><p>You just need to know that the forum layout is set for the topic category and all forums of this category will extend the layout. So if you should have two top categories with different layouts.</p><p> </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/general-questions/">wpForo</category>                        <dc:creator>Tom</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-questions/i-would-like-to-use-the-question-and-answer-layout-as-well-as-the-extended-layout-on-the-same-installation/#post-12749</guid>
                        <title>I would like to use the question and answer layout as well as the extended layout on the same installation</title>
                        <link>https://gvectors.com/forum/general-questions/i-would-like-to-use-the-question-and-answer-layout-as-well-as-the-extended-layout-on-the-same-installation/#post-12745</link>
                        <pubDate>Wed, 02 Jan 2019 09:28:20 +0000</pubDate>
                        <description><![CDATA[Is this possible or will I have to use another plugin like DW question and answer pro.Thanks and happy New Year everyone,Greg]]></description>
                        <content:encoded><![CDATA[<p>Is this possible or will I have to use another plugin like DW question and answer pro.</p><p>Thanks and happy New Year everyone,</p><p>Greg</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-questions/i-would-like-to-use-the-question-and-answer-layout-as-well-as-the-extended-layout-on-the-same-installation/#post-12745</guid>
