									Feature request: Specify number of rating levels in &quot;Member Reputation and Titles&quot; section - wpForo				            </title>
            <link>https://gvectors.com/forum/general-questions/feature-request-enable-disable-rating-levels-in-member-reputation-and-titles-section/</link>
            <lastBuildDate>Fri, 15 May 2026 04:34:49 +0000</lastBuildDate>
                        <title>RE: Feature request: Specify number of rating levels in &quot;Member Reputation and Titles&quot; section</title>
                        <link>https://gvectors.com/forum/general-questions/feature-request-enable-disable-rating-levels-in-member-reputation-and-titles-section/#post-23211</link>
                        <pubDate>Thu, 21 May 2020 19:25:23 +0000</pubDate>
                        <description><![CDATA[I found a workaround for this using the second solution proposed above, i.e. to stop the Member Activity section from displaying underneath the Profile tab. Confusingly, to hide this section...]]></description>
                        <content:encoded><![CDATA[<p>I found a workaround for this using the second solution proposed above, i.e. to stop the Member Activity section from displaying underneath the Profile tab. Confusingly, to hide this section I needed to untick "Front - Can view member reputation" for all the usergroups I want to hide this section from. I say confusingly because although this section is titled Member Activity it's different from the content of the member's Activity tab. gVectors - maybe this section (i.e. the one with the reputation data plus other data) should be renamed something like Member Stats to avoid this confusion?</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/general-questions/">wpForo</category>                        <dc:creator>Jamie</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-questions/feature-request-enable-disable-rating-levels-in-member-reputation-and-titles-section/#post-23211</guid>
                        <link>https://gvectors.com/forum/general-questions/feature-request-enable-disable-rating-levels-in-member-reputation-and-titles-section/#post-23206</link>
                        <pubDate>Thu, 21 May 2020 14:14:41 +0000</pubDate>
                        <description><![CDATA[Another solution would be to disable Member Activity from displaying on users&#039; Profiles. More drastic but would actually work well for our needs - is there any way to do that?]]></description>
                        <content:encoded><![CDATA[<p>Another solution would be to disable Member Activity from displaying on users' Profiles. More drastic but would actually work well for our needs - is there any way to do that?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-questions/feature-request-enable-disable-rating-levels-in-member-reputation-and-titles-section/#post-23206</guid>
                        <title>Feature request: Specify number of rating levels in &quot;Member Reputation and Titles&quot; section</title>
                        <link>https://gvectors.com/forum/general-questions/feature-request-enable-disable-rating-levels-in-member-reputation-and-titles-section/#post-23205</link>
                        <pubDate>Thu, 21 May 2020 14:07:23 +0000</pubDate>
                        <description><![CDATA[We only use want to use 5 rating levels for members, not the full 10 which is the default, so we&#039;ve set the &quot;min number of posts&quot; totals for levels 6-10 artificially high so that they&#039;re not...]]></description>
                        <content:encoded><![CDATA[<p>We only use want to use 5 rating levels for members, not the full 10 which is the default, so we've set the "min number of posts" totals for levels 6-10 artificially high so that they're not used in practice. However, on members' profile pages the maximum rating level now displays as 5/10 which some members are not happy with (understandably). I don't see how we can fix this situation without implementing 10 levels? It would be good to be able to specify the number of active levels in the Settings -&gt; Members tab so that the rating displayed on members' profile page uses the same for the maximum, e.g. 5/5 in this case.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-questions/feature-request-enable-disable-rating-levels-in-member-reputation-and-titles-section/#post-23205</guid>
