wpForo Advanced Attachments Version 1.3.0
(@andreasbln)
After the last update, the settings can no longer be saved. The specification of the upload size was simply changed to bytes, from the setup 2 GB was now simply 2 bytes. Well you can not change, because the plugin, after clicking on the Save button saves nothing. After the next call of the setup page, all old values are back.
The upload button has been removed, but there is now a text there. Very bad, for mobile. That the text is a link is not recognizable for everyone. Makes the tool useless.
The update is very bad, not meant for the people who want to use it.
Can the old version be used with the current version of WPforo?
Hi @andreasbln,
There is no such issue on our test websites. Please check and make sure there are no JS errors. JS errors can be found under the Console tab.
The upload button has been removed, but there is now a text there. Very bad, for mobile.That the text is a link is not recognizable for everyone. Makes the tool useless.
We've made the upload images feature more convenient for users. Now they can just Drag files or Copy image from PC or other devices and paste in the editor.  So this is not just a text it's notifying users how they can do for uploading images.
