[Solved] I lost the attach file feature for Registered Users
(@synergy)
Good day admin and thanks for the good work in wpforo
After some settings in Dashboard>forum>settings  I discovered that I have lost the attach file option in for registered users as seen on this screenshot. But the admin still have the option.
Please how do I fix that pls
Screenshot 20200226 120037
 Thank you guys so much
Hi @synergy,
wpForo has a New User Control function in Antispam settings. It allows you to set a minimum number of posts user must have to be able to attach a file or post a link. Please navigate to Dashboard > Forums > Tools admin page and manage the mentioned option in Antispam > New Registered user section. Set it 0, then delete all caches and check again.
In the case of mobile devices please test it on other mobile devices or try on incognito mode. Because mobile browsers have a hard cache, you'll not be able to see the change immediately.
@synergy
This topic is moved to the correct subforum.
(@synergy)
  • Thank you so much
(@synergy)
I also can't  find the move button to help me moderate posts. I can't see it as the admin and same for a moderator all of whom I enabled all permissions in forum access settings.
Find the screenshot
Screenshot 20200226 191020
@synergy,
The move button is located under the topic title. See the screenshot below:
move
More info here: https://wpforo.com/community/wpforo-announcements/wpforo-1-4-6-is-released/#post-14432
