									Emojis missing in drop down menue - General Discussion and Feedback				            </title>
            <link>https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/</link>
            <lastBuildDate>Sat, 08 Aug 2026 22:09:28 +0000</lastBuildDate>
                        <title>RE: Emojis missing in drop down menue</title>
                        <link>https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23368</link>
                        <pubDate>Tue, 26 May 2020 08:33:44 +0000</pubDate>
                        <description><![CDATA[Ah ok. If the updates are shown up through the normal wordpress update procedure, that will be enough. I wondered wether this would happend or not. Thank you for the info and for your help.]]></description>
                        <content:encoded><![CDATA[<p>Ah ok. If the updates are shown up through the normal wordpress update procedure, that will be enough. I wondered wether this would happend or not. Thank you for the info and for your help.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/general-forums/">General Discussion and Feedback</category>                        <dc:creator>thd</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23368</guid>
                        <link>https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23354</link>
                        <pubDate>Tue, 26 May 2020 07:28:21 +0000</pubDate>
                        <description><![CDATA[@thd
Basically WordPress checks for new updates every 8-12 hours. But you can do it manually from Dashboard &gt; Updates page, but only do it when you have some problem with the plugin and ...]]></description>
                        <content:encoded><![CDATA[<p>@thd</p>
<p>Basically WordPress checks for new updates every 8-12 hours. But you can do it manually from Dashboard &gt; Updates page, but only do it when you have some problem with the plugin and need to check for updates.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/general-forums/">General Discussion and Feedback</category>                        <dc:creator>Taron</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23354</guid>
                        <link>https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23332</link>
                        <pubDate>Mon, 25 May 2020 21:17:15 +0000</pubDate>
                        <description><![CDATA[@taron new updates on an existing addon]]></description>
                        <content:encoded><![CDATA[<p>@taron new updates on an existing addon</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23332</guid>
                        <link>https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23330</link>
                        <pubDate>Mon, 25 May 2020 20:36:28 +0000</pubDate>
Did you mean that the new add-on has been published? Or does the existing addon/plugin have a new update?]]></description>
<p>Did you mean that the new add-on has been published? Or does the existing addon/plugin have a new update?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23330</guid>
                        <link>https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23327</link>
                        <pubDate>Mon, 25 May 2020 20:21:10 +0000</pubDate>
                        <description><![CDATA[@taron That solved the problem. Thank you.
How do I know if a new plugin is available? Do I have to check that manually?]]></description>
                        <content:encoded><![CDATA[<p>@taron That solved the problem. Thank you.</p>
<p>How do I know if a new plugin is available? Do I have to check that manually? </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23327</guid>
                        <link>https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23319</link>
                        <pubDate>Mon, 25 May 2020 19:23:14 +0000</pubDate>
                        <description><![CDATA[Hi @thd.
Please update to wpDiscuz Emoticons v7.0.1. The issue should be fixed.]]></description>
                        <content:encoded><![CDATA[<p>Hi <span>@thd.</span></p>
<p>Please update to wpDiscuz Emoticons v7.0.1. The issue should be fixed.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23319</guid>
                        <title>Emojis missing in drop down menue</title>
                        <link>https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23314</link>
                        <pubDate>Mon, 25 May 2020 16:41:56 +0000</pubDate>
                        <description><![CDATA[As shown in the graphic, the emojis of the emoticons add on are not shown in the drop down menue. However when I click on them, they are correctly insertet in the comments text. How can I fi...]]></description>
                        <content:encoded><![CDATA[4503
<p>As shown in the graphic, the emojis of the emoticons add on are not shown in the drop down menue. However when I click on them, they are correctly insertet in the comments text. How can I fix this?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/general-forums/emojis-missing-in-drop-down-menue/#post-23314</guid>
