									Wp Discus Emoticons dont work - wpDiscuz Emoticons				            </title>
            <link>https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/</link>
            <lastBuildDate>Sat, 08 Aug 2026 13:31:36 +0000</lastBuildDate>
                        <title>RE: Wp Discus Emoticons dont work</title>
                        <link>https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24946</link>
                        <pubDate>Fri, 14 Aug 2020 12:12:29 +0000</pubDate>
                        <description><![CDATA[@astghik many thanks for the explanation, it works fine now.]]></description>
                        <content:encoded><![CDATA[@astghik many thanks for the explanation, it works fine now.]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/emoticons/">wpDiscuz Emoticons</category>                        <dc:creator>Rjk</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24946</guid>
                        <link>https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24944</link>
                        <pubDate>Fri, 14 Aug 2020 11:48:35 +0000</pubDate>
                        <description><![CDATA[Also, please try on incognito mode if you&#039;re checking on mobile devices. Because mobile browsers have a hard cache, you&#039;ll not be able to see the change immediately.]]></description>
                        <content:encoded><![CDATA[<p>Also, please try on <strong><em>incognito mode</em></strong> if you're checking on mobile devices. Because mobile browsers have a hard cache, you'll not be able to see the change immediately.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/emoticons/">wpDiscuz Emoticons</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24944</guid>
                        <link>https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24943</link>
                        <pubDate>Fri, 14 Aug 2020 11:45:42 +0000</pubDate>
                        <description><![CDATA[@rjk,
As it&#039;s already mentioned here we don&rsquo;t recommend disabling the rich editor if you have installed&nbsp;wpDiscuz Emoticons&nbsp;and&nbsp;wpDiscuz Comment &amp; User Mentioning&amp;nb...]]></description>
                        <content:encoded><![CDATA[<p>@rjk,</p>
<p>As it's already mentioned <a href="https://wpdiscuz.com/docs/wpdiscuz-7/plugin-settings/comment-form/#load-rich-editor" target="true">here</a> we don&rsquo;t recommend disabling the rich editor if you have installed&nbsp;<a href="../../../product/wpdiscuz-emoticons/">wpDiscuz Emoticons</a>&nbsp;and&nbsp;<a href="../../../product/wpdiscuz-comment-author-info/">wpDiscuz Comment &amp; User Mentioning</a>&nbsp;addons. These two addons add new toolbar buttons for selecting &ldquo;Emojis&rdquo;, &ldquo;Stickers&rdquo;, &ldquo;Users&rdquo;. If you disable the rich editor, the addons buttons will be disabled as well. We recommend just disable the toolbar formatting buttons using the next option, instead of disabling the whole rich editor.</p>
<p><span>So the solution is easy, just enable the "Load Rich Editor" option for mobile devices.&nbsp;</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24943</guid>
                        <link>https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24942</link>
                        <pubDate>Fri, 14 Aug 2020 11:35:15 +0000</pubDate>
                        <description><![CDATA[@astghik here it is]]></description>
                        <content:encoded><![CDATA[@astghik here it is https://tinyurl.com/y2ucx2x2]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24942</guid>
                        <link>https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24937</link>
                        <pubDate>Fri, 14 Aug 2020 08:31:51 +0000</pubDate>
Please leave some example URL to allow us to check the issue.&nbsp;]]></description>
<p>Please leave some example URL to allow us to check the issue.&nbsp;</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24937</guid>
                        <link>https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24931</link>
                        <pubDate>Thu, 13 Aug 2020 16:40:20 +0000</pubDate>
                        <description><![CDATA[i would like to add, that at the pc they work, not at Android]]></description>
                        <content:encoded><![CDATA[<p>i would like to add, that at the pc they work, not at Android</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24931</guid>
                        <title>Wp Discus Emoticons dont work</title>
                        <link>https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24928</link>
                        <pubDate>Thu, 13 Aug 2020 14:38:51 +0000</pubDate>
                        <description><![CDATA[the emoticons dont work since i upgraded. Any help would be aprediated.]]></description>
                        <content:encoded><![CDATA[<p>the emoticons dont work since i upgraded. Any help would be aprediated.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/wp-discus-emoticons-dont-work/#post-24928</guid>
