									Text-based emoticons using colons possibly broken by umlaut fix in 7.1.2 - wpDiscuz Emoticons				            </title>
            <link>https://gvectors.com/forum/emoticons/text-based-emoticons-using-colons-possibly-broken-by-umlaut-fix-in-7-1-2/</link>
            <lastBuildDate>Fri, 14 Aug 2026 09:37:47 +0000</lastBuildDate>
                        <title>RE: Text-based emoticons using colons possibly broken by umlaut fix in 7.1.2</title>
                        <link>https://gvectors.com/forum/emoticons/text-based-emoticons-using-colons-possibly-broken-by-umlaut-fix-in-7-1-2/#post-42036</link>
                        <pubDate>Fri, 11 Jul 2025 19:30:34 +0000</pubDate>
                        <description><![CDATA[Excellent!  Great job, too.  Use of colons in the text boxes appears to be completely fixed and working exactly as expected.  Thank you!  I have updated to the latest.]]></description>
                        <content:encoded><![CDATA[<p>Excellent!  Great job, too.  Use of colons in the text boxes appears to be completely fixed and working exactly as expected.  Thank you!  I have updated to the latest.</p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/emoticons/">wpDiscuz Emoticons</category>                        <dc:creator>Wolf</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/text-based-emoticons-using-colons-possibly-broken-by-umlaut-fix-in-7-1-2/#post-42036</guid>
                        <link>https://gvectors.com/forum/emoticons/text-based-emoticons-using-colons-possibly-broken-by-umlaut-fix-in-7-1-2/#post-42028</link>
                        <pubDate>Tue, 08 Jul 2025 10:52:21 +0000</pubDate>
                        <description><![CDATA[The issue is fixed. Please update the addon to the latest version.]]></description>
                        <content:encoded><![CDATA[<p>The issue is fixed. Please update the addon to the latest version. </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/emoticons/">wpDiscuz Emoticons</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/text-based-emoticons-using-colons-possibly-broken-by-umlaut-fix-in-7-1-2/#post-42028</guid>
                        <link>https://gvectors.com/forum/emoticons/text-based-emoticons-using-colons-possibly-broken-by-umlaut-fix-in-7-1-2/#post-42019</link>
                        <pubDate>Mon, 07 Jul 2025 09:30:34 +0000</pubDate>
                        <description><![CDATA[We&#039;ll check this soon.]]></description>
                        <content:encoded><![CDATA[<p>We'll check this soon. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/text-based-emoticons-using-colons-possibly-broken-by-umlaut-fix-in-7-1-2/#post-42019</guid>
                        <title>Text-based emoticons using colons possibly broken by umlaut fix in 7.1.2</title>
                        <link>https://gvectors.com/forum/emoticons/text-based-emoticons-using-colons-possibly-broken-by-umlaut-fix-in-7-1-2/#post-42013</link>
                        <pubDate>Sun, 06 Jul 2025 05:28:39 +0000</pubDate>
                        <description><![CDATA[Hi!  I would like to report a new bug and an old bug in the Emoticons Add-on.
The umlaut fix for German keyboards here:
...which just went in with the latest Emoticons add-on version 7.1.2...]]></description>
                        <content:encoded><![CDATA[<p>Hi!  I would like to report a new bug and an old bug in the Emoticons Add-on.</p>
<p>The umlaut fix for German keyboards here:</p>
<p>https://wpdiscuz.com/community/postid/28934/</p>
<p>...which just went in with the latest Emoticons add-on version 7.1.2, seems to have broken the colon-based entry of emoticons on US keyboards, such as:</p>
<p>:joy:</p>
<p>:flag-us:</p>
<p>etc.</p>
<p>Basically, typing colon plus alphanumerics does not pop up the small top-level window / tool tip needed to select an emoticon.</p>
<p>I tried deleting the cache, etc.  None of these helped.</p>
<p>My temporary fix has been to revert to the add-on version that I just purchased recently, which is 7.0.16 - this immediately fixed the problem, so I'm certain it's simply something with the colon.</p>
<p>I should also note that even in earlier versions of the add-on, US keyboards have always had a problem with regular single colons in text, reliably causing the emoticon selection pop-up to periodically show and not show and show again, until a second colon is typed.</p>
<p>I should note that I am using Linux with US English default and no alternate input keys, dead keys, etc., such as those like colon which are commonly used with International English, to generate umlauts.</p>
<p>Hoping this helps diagnose the problem.  Thanks in advance!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/text-based-emoticons-using-colons-possibly-broken-by-umlaut-fix-in-7-1-2/#post-42013</guid>
