									Display issue - wpDiscuz Emoticons				            </title>
            <link>https://gvectors.com/forum/emoticons/display-issue/</link>
            <lastBuildDate>Fri, 13 Nov 2026 20:22:59 +0000</lastBuildDate>
                        <title>RE: Display issue</title>
                        <link>https://gvectors.com/forum/emoticons/display-issue/#post-32843</link>
                        <pubDate>Thu, 14 Jul 2022 10:43:19 +0000</pubDate>
                        <description><![CDATA[@astgh : thank you very much, it&#039;s work ! 👍]]></description>
                        <content:encoded><![CDATA[@astgh : thank you very much, it's work ! 👍]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/emoticons/">wpDiscuz Emoticons</category>                        <dc:creator>Fabien</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/display-issue/#post-32843</guid>
                        <link>https://gvectors.com/forum/emoticons/display-issue/#post-32840</link>
                        <pubDate>Thu, 14 Jul 2022 10:16:36 +0000</pubDate>
                        <description><![CDATA[@steelbookpro,
This is again a small CSS conflict with the theme or other plugins.
The code below should solve the issue:
#wpdcom .wpd-comment-text img {
   float: none;
   border: none...]]></description>
                        <content:encoded><![CDATA[<p>@steelbookpro,</p>
<p>This is again a small CSS conflict with the theme or other plugins.</p>
<p>The code below should solve the issue:</p>
<pre contenteditable="false">#wpdcom .wpd-comment-text img {
   float: none;
   border: none;
   padding: 0;
}</pre>
<p>The code in the previous post can be removed. </p>]]></content:encoded>
						                            <category domain="https://gvectors.com/forum/emoticons/">wpDiscuz Emoticons</category>                        <dc:creator>Astghik</dc:creator>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/display-issue/#post-32840</guid>
                        <link>https://gvectors.com/forum/emoticons/display-issue/#post-32839</link>
                        <pubDate>Thu, 14 Jul 2022 10:10:15 +0000</pubDate>
                        <description><![CDATA[@astgh : thanks, it works, but there is still the frame around the emoticons. Do you have an idea of ​​the problem ?]]></description>
                        <content:encoded><![CDATA[@astgh : thanks, it works, but there is still the frame around the emoticons. Do you have an idea of ​​the problem ?]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/display-issue/#post-32839</guid>
                        <link>https://gvectors.com/forum/emoticons/display-issue/#post-32838</link>
                        <pubDate>Thu, 14 Jul 2022 09:32:13 +0000</pubDate>
Use the CSS code below: 
#wpdcom .wpd-comment-text img{
       float: none;
Put the code in the Top Admin Bar &gt; Customize &gt; Additional CSS &gt; &quot;Additional CSS&quot; t...]]></description>
<p>Use the CSS code below: </p>
<pre contenteditable="false">#wpdcom .wpd-comment-text img{
       float: none;
}</pre>
<p><span>Put the code in the Top Admin Bar &gt; Customize &gt; Additional CSS &gt; "Additional CSS" textarea, save it, delete all caches and check again.</span></p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/display-issue/#post-32838</guid>
                        <link>https://gvectors.com/forum/emoticons/display-issue/#post-32837</link>
                        <pubDate>Thu, 14 Jul 2022 09:01:58 +0000</pubDate>
                        <description><![CDATA[@astgh : here an URL exemple :]]></description>
                        <content:encoded><![CDATA[@astgh : here an URL exemple : https://steelbookpro.fr/2022/06/27/dracula-1993-steelbook-4k/]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/display-issue/#post-32837</guid>
                        <link>https://gvectors.com/forum/emoticons/display-issue/#post-32836</link>
                        <pubDate>Thu, 14 Jul 2022 07:58:59 +0000</pubDate>
                        <description><![CDATA[BTW, your topic has been moved to the correct forum.]]></description>
                        <content:encoded><![CDATA[<p>BTW, your topic has been moved to the correct forum. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/display-issue/#post-32836</guid>
                        <link>https://gvectors.com/forum/emoticons/display-issue/#post-32835</link>
                        <pubDate>Thu, 14 Jul 2022 07:58:02 +0000</pubDate>
Please leave the example URL to allow us to check the issue.]]></description>
                        <content:encoded><![CDATA[<p><span>@steelbookpro,</span></p>
<p>Please leave the example URL to allow us to check the issue. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/display-issue/#post-32835</guid>
                        <title>Display issue</title>
                        <link>https://gvectors.com/forum/emoticons/display-issue/#post-32832</link>
                        <pubDate>Wed, 13 Jul 2022 09:50:00 +0000</pubDate>
                        <description><![CDATA[Hello,
Since the last update of wpdiscuz, I have a problem with emoticons display. You can see it in the picture : emoticons are all at the left and they are framed. Do you have an idea of ...]]></description>
                        <content:encoded><![CDATA[<p>Hello,</p>
<p>Since the last update of wpdiscuz, I have a problem with emoticons display. You can see it in the picture : emoticons are all at the left and they are framed. Do you have an idea of ​​the problem ? <br />Thanks ! </p>
6121
6120]]></content:encoded>
                        <guid isPermaLink="true">https://gvectors.com/forum/emoticons/display-issue/#post-32832</guid>
