[Solved] File extensions case sensitive and add-on not mobile ready
(@wilcosky)
Here are the two main issues I am having so far:
1) It seems like the allowed file types are case sensitive. If I try to upload an image with .JPG (all caps), it says it is not allowed. If I add JPG to the allowed list, along with lower case jpg, then it works. For now, I'll just add the all caps versions for the most popular file types. But, it would be nice if this was fixed. Anyway to make this part not case sensitive?
2) This add-on isn't mobile ready. It is very hard to get a picture inserted using my iPhone. I'm on my iPhone right now and the main forum works great. But, not this add-on. The check boxes get cut off and you must go into landscape mode to see them (to check off the images to insert). Things tend to hop around and overall it gets frustrating to use very fast. Also, the lightboxes that enlarge the images when tapped don't seem to be responsive.
Hi William,
please find my answers below:
Thank you for letting us know, we're currently fixing this issue and will update this addon very soon.
Only just uploaded files have checked option to insert into post, if you upload a file you don't need to uncheck it in 99% cases. So this is the main reason why it's not available as a big action button. And yes all parts of this addon are under improvement, the development is not finished, so the small mobile issues will also be fixed.
2017 01 06 1252
(@wilcosky)
Thank you very much! I'm very grateful for this forum system. I know a lot of hours went into creating it and overall, it is fantastic!
(@wilcosky)
I've realized that I probably wasn't doing something right. This add-on seems to work fine on my iPhone today and is responsive.
So, the file extensions being case sensitive is the only issue.
We just released wpForo Advanced Attachments 1.0.2 version. Please update or delete your installation, download from gVectors Account page and install the new version.
Changelog - v1.0.2
  • Fixed Bug: Problems with HTTPS websites.
  • Fixed Bug: Case sensitive issue in allowed file extensions list.
