[Solved] "Attach Files" does nothing
 Matt
(@twistednormal)
 Hi
Just installed the add-on, as the topic title says, nothing happens when clicking on "Attach Files", any idea?
here's the forum:  http://www.twistednormal.com/community/
Please let me know the WordPress/wpForo versions. Also, Have you deleted all caches after installing wpForo Advanced Attachments addon?
You have a jQuery error on your website, this affects wpForo addon. Please fix this error:
I see the JS file source is located in /wordpress/ subdirectory. Maybe you've moved WordPress to root not properly or you've made some changes in file structure. All these can affect other plugins, as well as wpForo addons.
 Matt
(@twistednormal)
Hi and Thank your for your message
WordPress is version 4.7, wpForo is 1.1.1
Thanks for the image, everything is just out-of-the-box, but Im investigating.. thanks
 Matt
(@twistednormal)
we just moved wordpress from root to a subfolder as described here:
https://codex.wordpress.org/Giving_WordPress_Its_Own_Directory
Is there something I should check or investigate further?
