RE: RE: Incompatible with SlimStats
(@taxick)
Hi.
The plugin is incompatible with Slimstats!!
When wpDiscuz Widgets is enabled the SlimStats settings look like this:
When wpDiscuz Widgets is disabled it look correct:
Any fix for this?
Kind regards Thomas
Ok, thank you for letting us know, we'll check and update wpDiscuz Widgets asap.
(@taxick)
From the author of slimstats:
I assume it's a conflict with their CSS code, that for some reason hides the checkboxes in the Settings screen. Please check with them to see if they can address this issue on their end.
Best,
Jason
(@taxick)
Any news ?
Hi Taxick,
it's already done, we're planning to release new version tomorrow.
