[Solved] comment translation bug
 Asaf
(@asafbraverman)
Dear Team,
Very much appreciate your plugin. I just purchased the comment translation addon and noticed that it creates a bug on some of my pages. See here (scroll down to bottom of page):  http://dev2.beperiod.com/en/
Here is an example of a post with comments:  http://dev2.beperiod.com/en/posts/to-see-or-not-to-see/
Please advise.
Thanks,
Asaf
Hi Asaf,
We've fixed this issue. The new 1.0.1 version is released please update.
 Asaf
(@asafbraverman)
Hello Tom,
Just purchased and installed your comment flagging addon and experienced the same bug as above. See here (scroll down to bottom of page): http://dev2.beperiod.com/en/
/a>
This probably requires a similar fix - please let me know.
Thanks,
Asaf
Hi Asaf,
something specific exists in your theme which kills all our addon pop-up scripts, that's very strange, however we're currently working to find general solution for this, I'll update this topic once the new version is released.
Thank you!
 Asaf
(@asafbraverman)
Thanks Tom,
Your last update seems to have fixed it. The Divi theme I use is very popular, so fixing bugs associated with it will probably be helpful to future clients.
Thanks for the prompt support!
Asaf
