WooCommerce Product Tab Issues
(@petaframe)
I've got a few questions.
1. How can I translate the front-end title 'discusstion'? I can't find any options on settings, nor .mo file doesn't work.
2. As you can see on the screenshot, the 'discussions' affects on the '리뷰(Review)' tab's title. How can I fix it?
3. I tried wpDiscuz instead of this plugin, and it seems better for me. But it replaces product 'Review' tab, when I use wpDiscuz on product. How can I use wpDiscuz and WooCommerce 'Review' tab together?
(@varos)
Estimable Member
Hi petaframe,
In the dashboard, WooDiscuz front-end phrases you can change. Take closer look please: https://wordpress.org/plugins/woodiscuz-woocommerce-comments/screenshots/
Also, the screenshot does not work, check again.
Please note: wpDiscuz is not for products/WooCommerce, for it, you can use WooDiscuz for e-commerce.
