I want to add some formatted text into the comment form - below the comment text field, but above the other fields and submit button. I tried to use the action hooks of WP but only comment_form_before and comment_form_top are working.
The text is a short explanation how the users can add source code to their comments. How can I add my text?
Thanks a lot.
I'm sorry but there is no way to add text between comment fields yet. You should put it above ore below comment form.
Ok, I found a way to add my text:
I inserted it in
/wp-content/plugins/wpdiscuz/forms/wpdFormAttr/Form.php
But it would be great, if you could add the possibility to add a simple (formatted) textbox in the form builder. I fear my changes will be gone on next update...
