Avatar Upload: wpFo...
[Solved] Avatar Upload: wpForo
gpatkins
(@gpatkins)
Is there a way to allow cropping of an image that is loaded as your profile pic?
gpatkins
(@gpatkins)
Also: When a image is loaded as your profile pic and then changed it does not seem to update. Any advice?
I even tested it in your own forums here and it does not update.
Hi gpatkins
I'm sorry but there is no such a way. We'll add it in our to-do list for future releases.
wpForo has built-in user caching system. That's cache issue, you just need to do Ctrl+F5 on front-end to load the new image. Or just use [delete users cache] button in Dashboard > Forum > Dashboard admin page. Also you can disable user caching in Forums > Settings > Features admin page.
gpatkins
(@gpatkins)
Thanks for the response!
(@jfmgarrido)
Posted by: Tom
Hi!
Sorry for bring this topic to life again but I'm with the same problem (avatars don't update after upload a new one) and I've tried all the actions mentioned above but nothing happens, the older image persists in the profile. Some new action that I can take to solve this issue?
Thanks in advance.
