No way to add to pa...
[Solved] No way to add to pages??
(@maneperson)
I have a clean install and can't find any way to make this show up on pages, only posts.  I see a lot of people asking for help with this but not a single verified answer. All of your instructions fade away from pages and end up talking about posts. I have tried all of your recommended solutions and none apply. Why is this so hard?? Why is there nothing in the directions?? If answers are out there I was not able to find them.
Posted : 07/01/2017 11:29 pm
Hi maneperson,
could you please let me know what plugin you're talking about?
If you mean wpDiscuz, please navigate in Dashboard to Comments > Forms and edit the Default Form then enable this form for Pages.
wpDiscuz custom post type settings
Posted : 08/01/2017 1:04 am
(@maneperson)
Sorry, I should have posted that it was for Discuz. I finally did find that in the forms section and got it to show up.  I think I found it in a question about including another kind of page but it applied.  I had some question on how the voting system works as well. I can post a new question unless you have a quick link to something.
Thanks very much!
Posted : 08/01/2017 7:20 am
